OT: 2007 Cobalt LS 4DR
Username: Fac3l3ss
Post Number: 148
hi everyone..to begin i'll make this short and to the point. i'm looking for a system for my car and would greatly appreciate some help.
Username: Fac3l3ss
Post Number: 149
http://www.mobiletoys.com/partners/jvc_fitguide/pages/mobileEntertainment/produc tSelection.aspx
that's the link to jvc's mobile audio site..i might like to go with jvc i was actually quite impressed with my last hu and speakers i bought...has anyone heard these speakers..and i was thinking of also getting the kameleon hu...any input appreciated
Username: Fac3l3ss
Post Number: 150
i like to very fine tune my music..a 3 band parametric iEQ...better than have a 7 band eq? and how many preouts does kameleon have and volts/channel? i might not make much sense but i'm new to this and want a good sq system
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2478
What all are you looking for? Speakers, subs, amps, HU?
Username: Fac3l3ss
Post Number: 151
a hu, amp, and front 6.5 speakers
Username: Dirtrider125
Post Number: 118
id get a alpine amp and speakers and if u want a jv hu id get this http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19062
Username: Fac3l3ss
Post Number: 152
i looked up alpine type s on youtube and they looked decent...alpine good sq?
Username: Drant19
DUB-C, TX
Post Number: 884
how much do u want to spend on everything?
"i'm new to this and want a good sq system"
SQ is not cheap...
Username: Ctmike
Ct.
Post Number: 6084
you could buy my 15" atlas for cheap. great sq sub:-)
Username: Fac3l3ss
Post Number: 153
alpine and rf are two brands i can get my hands on around here through local stores..which is better sq?
Username: Fac3l3ss
Post Number: 154
for an amp, hu and two good 6.5 and 6x9 speakers i'd like to stay under $1000 i don't have to have the 6x9's right now though..just 6.5's to replace current ones
Username: Fac3l3ss
Post Number: 155
if i can get away with just an amp and two 6.5's that would be okay as well as long as i'd be able to use the stock hu
Username: Drant19
DUB-C, TX
Post Number: 885
i would just leave the stock 6x9s and run them off the headunit. a good sound stage has all the sound coming in front of you.
HU-Alpine 9886 ~270
Comps-alpine spxPRO 6.75" ~360
Comp Amp-Alpine F450 200rmsx2 bridged @4ohms OR RF P450.4 Both are ~200 online
theres too many options you can get.
Username: Fac3l3ss
Post Number: 156
there is no place unless modified i can fit those tweeters?...i don't want to modify..so unfortunately i have to go without components..unless there is a way you can install those tweeters without cutting away at dashboard
Username: Fac3l3ss
Post Number: 157
keep in mind i don't want to have to modify my power supply at all or very little
Username: Fac3l3ss
Post Number: 158
this setup is not for competition just everyday driving to and from work 45 minute drive each way
Username: Drant19
DUB-C, TX
Post Number: 886
if you have stock tweeters, see if you can just switch them out
Username: Fac3l3ss
Post Number: 160
i don't have stock tweeters on my dashboard
