No 1 is helping me!!!!
Username: Cricket674
Post Number: 226
plz someone juest help me!!! My Pansat 2700 had good quality and signal b4 i put the new bin but when i put it didnt had any quality and 30% quality and i had touch nothing
Username: Dimwitt
Post Number: 675
30% signal usually means you connected cable to antenna in , instead of lnb in
Username: Nydas
Post Number: 10562
Tooter: That is very good trouble shooting.
And I mean it.
Post Number: 227
I did put it in the satellite in but still not working. I put everything in the right place.b4 putting the bin the signals were really good.i used nalins procedure
Username: Gregraf
Post Number: 500
Well theres the problem.
Post Number: 228
wat do u mean......
explain
Username: Nydas
Post Number: 10566
Bobby Joe: What is you receiver and what BIN did you put using which one of my instructions?
Post Number: 229
my receiver is a converted Pansat 2700 (PUFF) i used the document in 265a_Puff_full kit
P.s i followed steps from A-D ( I thought i didn't need the others)
Username: Nydas
Post Number: 10569
You either use channel master and save (that will be for next time now) or you have do full set up of user settings and scanning. It is described in the instructions.
Username: Satopia
Post Number: 152
bobby check to make sure your sat settings are ok still, you may have cleared them some how, just make sure ports are correct and so on
Username: Kayoss
Post Number: 47
Bobby Joe.... Give up!.... this problem is clearly serious and hopeless. It is especially hopeless if you have to go to this site for help. This site is for entertainment, not technical support.
Username: Kaptaincock
Diamond Member
Post Number: 7
And nalin will just kill it if you take her advise !
Username: Larrydumass
Stuppitville, Ark Werdufunkarewe
Post Number: 51
do u no how easy it is to fry a lmb i did it a time or too ok everyone bash me now
Username: Satopia
Post Number: 154
BASH BASH BASH! LOL
Username: Luser
Post Number: 269
When insalling new bin on some pancrap you must redo antenna settings for each sat/lnb. For the exact settings we must know your dish/lnb and/or switches and type.
