Sony RDR-VX525 DVD Recorder Default Settings
Username: Bob2701
Hi, I need to know how to set this recorder back to factory default.
My wife was in the setup mode and did something and now nothing works. The remote can only turn it on or off, no other funtions. The display says DV or something like that.
I can't find my manual and cannot locate one online.
TIA Bob
Username: Ieee488
Post Number: 98
I'm not sure where you looked, but the manual is available for download from Sony.com
Username: Bob2701
Thanks, I don't know why I missed it the first time but they did have it.
I found that my Recorder was set to DVD 1 and the remote was set to default DVD 3.
All is well again.
Thanks, Bob
