sada i did not have a cahnce to thank you for your response . plz tell me after dowloading the latest bin . some poeple suggest to stay with 1.45 and connecting the cable to the router . how about emmulation : on or off????? and how long u wait for the pic to pick up. today my friend called me to help him with his nfusion. thanx
I HAVE THE LOADER 1.31 AND I DONT HAVE AN OPTION TO CHANGE MY PORT CAM IM USING LAPTAB WITH THE USB TO SERIAL. SO THE COM PORT IS 3 BUT IN THE LOADER THERE IS NO WAY TO FIND WHERE TO CHANGE THE COM SO I CAN DOWNLOAD VER 1.45. IF THE DOWNLOAD IS SUCCESSUFUL SADA GOING TO S/W I CAN SEE THIS VERSION INSTEAD OF R3XCAM......_U24 . THE LOADER IS DIFFEENT THAN THE ONE IN STEP BU STEP THANX BODY
SADA OK NEVER MIND I GOT THE WAY HOW TO DO IT SO FAR GGET OOD . ONLY EMULATION IS IT ON OR OFF . BUT I WATCH TV. I AHVE A QUESTION HOW TO MAKE A CHANNEL LIST BU SID NOT CHANNEL NUMBER AND ALSO THE INFORMATION HOW TO DO IT .
cartier emulation should be turned off. to make a channel list do u mean favorite channels menu edit favorite list and create favorite. with new bin u can create a backup/ channel list in order to do this u need to go to webbrowser type in ur nfusion ip adress on adress bar , u will see webloader, u can download the bin 1.46 or u can do it using serial, its not yet availablable through remote yet .
