Viewsat losing signal and Quality
Username: Dhabu
Boston, Ma Usa
Post Number: 14
I have Viewsat 900, when I load the file the signal and quality is there But the minute I change the channel both the quality and signal is lost leaving a blank screen.
My connections are good, and the reciever was good up till last two files which has been doing this, What can be the problem?
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 2270
bhavini
All viewsat box
Go to Code menu
Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00
Delete this 3 provider one by one with F3 on remote
"NEW" do same thing with all provider on Bev provider
09 07 00
09 06 00
09 05 00
09 01 00
08 01 00
no need to delete keys
and load last bin for your box
turn autoroll on
Keep on
Bin and autoroll regenerete keys
Thats erase bad data in the box
For box who autoroll and lost channels
I hope that work
Good luck
Thanks
Reply if it work
Please
Username: Dhabu
Boston, Ma Usa
Post Number: 15
Thank you and I will try this out today and
will let you know if it has worked.
Thank you.
Username: Plymouth
Post Number: 2278
Your welcome bhavini
Username: Cricket674
Post Number: 224
the same problem with me but I have a Pansat 2700 with Puff do i have to follow the same procedure.
Username: Plymouth
Post Number: 2280
I dont know Bobby
I dont have this box for test
Sorry
Note that can work too
