Hi! Can someone put some light on this cause I'm little confused.I have Marantz SR5300 and according to manual it takes 6-16 ohm speakers.The speakers I plan to get are(Eltax Monitor 3) and they are 4-8 ohm.Would it be safe to connect them and run in a long term.What I would like to say is if the speakers are 8 ohm than its clear,(ITS SAFE), or if amplif. takes 6 ohm its safe again, but with this between inf.its vey confusing to me. Please Help!!!
Thanks!!!!!!!!!!
Most likely it will be ok, as long as they are not plain 4 ohm speakers.
