OT- In need of a GOOD 2/4 channel amp any ideas?
Username: Safe_cracker
Chicago, IL US
Post Number: 4475
I need 200rms per channel into four channels at 4ohms or 400rms into two channels at 2ohm. I was looking at a Soundstream Van Gogh 800.2 any other ideas would be greatly appreciated... Polo..
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5768
SX fried?
Username: Loc_out
Santa Ana, Ca Resonant Eng...
Post Number: 2059
Polo you should know better. Please post on the right section. j/k
-Lowlife
Username: Insearchofbass
Post Number: 9160
brand new from Sonic Electronix...same power at 1-4 ohms and it has four channels
http://cgi.ebay.com/Brand-New-Pheonix-Gold-800-Watt-Multi-Channel-Xenon_W0QQitem Z260237492595QQihZ016QQcategoryZ39739QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Brand New Pheonix Gold 800 Watt Multi Channel Xenon
* 800 Watt Power Amplifier
* High efficiency (greater than 80%) Class D Operation
* Xe.load: optimized for any impedance load
* Xe.tune: 24dB Linkwitz-Riley subsonic and low pass crossovers
* Xe.flow: variable thermal feedback controlled fans
* Tried and true triple Darlington output stage
* Buffered RCA full range thru output
* Remote Monitoring Display (RMD) port
* Low Pass Level control ready (LPL-44)
* 200W x 4 (4-1 ohm stereo)
* 400W x 2 (8-2 ohm bridged)
* Built-in Crossovers
* Optional Remote Voltage Display
* Optional Remote Low-Pass Level Control
* Variable input sensitivty
* 0 - 18dB Bass Boost at 45Hz
* CEA-2006 Compliant
* Dimensions: 22" L x 10.6" W x 2.5" H
* 1-year Sonic Electronix warranty
Chicago, IL US
Post Number: 4476
I think the transformer is gone can't find the short and really don't have the time to fix it, sucks. I changed everything out, scoped out perfect, nice waveform used it in-car for a week and a half. I went to turn it on the other day and it shut off again, funny thing is it never went into protect and it never smoked BUT it did take a whole set of power supply fets with it, again just plain tired ya know? Polo..
Chicago, IL US
Post Number: 4477
Nice Sean it would be Ideal but it is a class D need it in A/B for use with comps needs to be clean. Polo.
Post Number: 5770
No I don't know, but I'm sorry that happened to you. It looks like Sean posted a winner, though.
Diamond Member
Post Number: 20762
rockford fosgate p850.2
* 2-channel car amplifier
* 225 watts RMS x 2 at 4 ohms (425 watts RMS x 2 at 2 ohms)
* 850 watts RMS x 1 in bridged mode (4-ohm stable in bridged mode)
* variable high- and low-pass filters (40-400 Hz, 12 dB per octave)
* wired Punch Bass EQ (0-18 dB at 45 Hz)
* Focused Mass Heatsink design
* removable connector cover
* TO-247 MOSFETs run cooler than standard transistors
* CEA-2006 compliant
* preamp inputs and outputs
* fuse rating: 40A x 3
* 4-gauge power and ground leads recommended -- wiring and hardware not included with amplifier
* 17-3/4"W x 2-1/8"H x 11"D
Post Number: 9161
wait scratch that its not through Sonic Electronix...he just copied that from them it looks like...but your not interested in it anyway
Username: Loc_out
Post Number: 2060
PG amp is a * High efficiency (greater than 80%) Class D Operation
Chicago, IL US
Post Number: 4479
Anyone have any experiences with US amps MD22's? Maybe a pair of them ? Polo.
Diamond Member
Post Number: 20763
good amps man. you can't go wrong.
why do you need so much power may i ask?
Username: Kickerman
Post Number: 220
would u sell the sx
Chicago, IL US
Post Number: 4480
The SX needs to be sent in to Kicker for repair. I am good repairing amps but when it is coupled with digital electronics (DSP board) it tends to complicate stuff, not to mention A/B can be a PITA. BTW Chad I just want enough power, the CVL's Sound best on 200rms, they get really loud just the way I like it. It is like me running my IA40 on a 16v system, you really don't need all that power but it is sure nice having it when you are in the mood to bump the punks in front of you! :-O Polo.
Username: Kickerman
Post Number: 221
i understand it needs to be repaired i just wanted 2 know if u would sell it as is
Chicago, IL US
Post Number: 4481
Yes. Polo.
Chicago, IL US
Post Number: 4482
Hey how are the little ALPINE MRP-F450 ? Was thinking about a pair of them. Polo..
