I'm looking to replace my 2 12" Power Acoustik MoFo's. I will probably be keeping the same amp for a while. It's a MA Audio HK-598. What I'm looking for is some $200 12"s that will be just as loud if not louder and have better sq. I have a 2000 stratus so Space is kinda an issue.
2 12s for 200 bucks? good luck. the best i can think of would be two audioque sdc2.5s, but you would be underpowering them. that amp you have is crap though. you should definitely get a new one. just save up money and do it right the first time. it will save you money in the long run.
Would anyone like to recommend an amp then? I really planned on upgrading it first anyway. I would like a good budget amp though nothing real expensive. I need 2400w at 2 ohm for the mofo's.
