How to figure out imp. rise
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 2058
wanna know where i can figure out if i can wire 2 dual 2 ohm subs to my 1606d.with out smoking it
Username: Peakohm
Post Number: 62
if you wire the coils in parallel and subs in series you'd get 2 ohms. there are other options but just a quick glance that looks like the way you'd get max power without killing the amp
Username: Nyyfan13
15 MAG USA
Post Number: 9518
You have the option of .5 ohm or 2 ohms or 8 ohms....Don't run that amp at .5 ohm.....run it at 2 ohms. What subs do you have?
Username: Cblaze
Post Number: 2060
right now 1 sx thankin about adding one more.guess if i do ill just get a second amp
Diamond Member
Post Number: 20692
if you add another sx then get the kicker kx2500.1. you can find one at a good price on ebay and it is 2ohm stable so it would be perfect for 2 sx's.
