Silver Member Username: Bones714Somewhere fi... Post Number: 402 Registered: Mar-05 | Just what the title says, I posted this in the Basic TV section but someone moved it. I purchased a 46" Samsung LCD a few months back and need an amplified antenna to get local HD channels. This unit has a built in HD tuner so I'm not looking for a HD tuner. Anyone has any suggestion What kind and where I can get a nice amplified antenna? Price is no issue, just need something that works good. |
Gold Member Username: Donnie1973Post Number: 3006 Registered: May-06 | it depends... if u live in or near a city that broadcasts local channels, u can get a cheap one or just a regular hd antenna for 10 bucks. I installed 3, 2 are within 20 miles (as a crow flies) from the city that broadcasts the channels that are regular ant's. 1 is around 30 miles and i went with a 30 dollar powered ant. all work great. walmart for all 3 |
Silver Member Username: Bones714Somewhere fi... Post Number: 403 Registered: Mar-05 | I live in the city, right now I have bunny ears hooked up to it. Sometimes I get a good signal for some channels but then again I have to play with it to catch others. Its just been a hassle messing with the one i have right now. It worked fine for my 32" Sony, but for some reason its not working that great for the my new LCD. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&Item=&Category=&_trksid=p3907.m29 I'm looking at this one on Ebay, i just dont want to drop $76 on something that doesnt work the way its suppose to, u know.. |
Silver Member Username: Bones714Somewhere fi... Post Number: 404 Registered: Mar-05 | http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26%26item%3D&ssPageName=STRK:MEWA: IT&ih=024 Link in my previous post didnt work, hit this one |
Bronze Member Username: RogybePost Number: 40 Registered: Dec-06 | OK here is something, I live about 50 miles from major TV stations and have largest Antenna that Winegard makes and Winegard PreAmp, and still have hard time to get clean strong signal, digital signal if you dont have enough just cut out, and I dont think the type of antenna makes any difference if you watching HD or not HD signal. |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 2726 Registered: Oct-06 | - First yo need to do survey to find out what yo can get: http://www.antennaweb.org/aw/Address.aspx - Second use this thread as reference https://www.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=1077210#POST1077210 - Third check this place and compare prices Cuz they can also assist yo with tech questions http://shop.willyselectronics.com/browse.cfm/2,15.html or http://www.solidsignal.tv/prod_display.asp?PROD=ANWGS1100&xzoom=Large#xview |
