If I had $1 for every cavi ive worked on, i'd have $5, lol.
Anyway, first start by removing the screw on top the dash where the vent is. Remove the plastic vent.
Then open up the glove box. There should be 3 gold screws, remove them all.
Now look under the dash for any screws.
Next, open each fuse box on each side of the dash, there should be one screw in each one to remove.
Now try and remove the top part of the dash around the steering wheel. Don't pull too hard, there are many hidden plugs and screws which are holding it on from the inside.
If you have an airbag on the passenger side, be extremely careful not to set it off, take your time removing the dash.
Once you start to get a lift up on the dash, there may be some screws which you need to remove. (depending on the year)
Once the dash is off, you should be able to see how everything comes apart.
GOOD LUCK TO YOU!
P.S.-I am pretty tired so im sorry if I repeated myself at some point or something doesn't make sense. I'll post better directions tomorrow for you if you don't understand something.
