Having trouble adding Bev 82 and 91 on one dish 500
Username: Arctick
Post Number: 39
I am having trouble adding Bev 82 and 91 together on Dish 500. I can only point to either 82 or 91. I tried putting together but didn't get single and doing separate I was able to get signal. I am using Dish pro LNB (dual). What am i doing wrong. Dish pro Lnb has 2 lnb and currently I am getting single for 82 but no luck getting 91. Any help would be appreciated. By the way I am in So.Cal .
Username: Kirankumar
NO Bashing
Post Number: 2694
rick
here is what you need to do
go to www.dishpointer.com put your address in and on the second line scroll down to 82/91 and hit go
now you will see the skew and elevation
adjust the skew and then mount dish
adjust elevation and point dish
get 91 set up first( this should be mounted on the right if you are facing the dish)
now dishpointer gives you direction to point.go ahead and do that
now check for quality
if it is not good adjust the elevation first until you get quality and then fine tune if needed by tweaking dish
good luck
Username: R_d_g
St. Louis, Missouri
Post Number: 27
Rick , If you are useing a dishpro dual as you stated, then that is your problem. To get both sats you need a dishpro twin.
NO Bashing
Post Number: 2699
rick
were you able to solve your problem?
