New member Username: Manemoj123Post Number: 1 Registered: May-08 | I just set up my dish to get 91W Nimiq 1 but not all the channels are there. All the transponders seem to be there but missing some of the channels. I have CW600P and signal is around 70 %. I'm missing TBS, Setanta, ESPN classic, and regular ESPN, channel 391 NCAA, SPEED US.... When I do a scan I get total of 230 channels on 91W. Dih settings are LNB Freq. 11250. Please provide your inputs. Thanks |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2103 Registered: Jan-08 | Bobby Check if your channels are only on Horizontal If yes check all cable or the switch |
Gold Member Username: KirankumarNO Bashing Post Number: 2660 Registered: Oct-07 | wait until b@v is up and running fully and then do another scan |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2104 Registered: Jan-08 | African No need bev is up for autoscan |
New member Username: Manemoj123Post Number: 2 Registered: May-08 | How many channels should I be getting on Nimiq1 91W??? |
Gold Member Username: KirankumarNO Bashing Post Number: 2666 Registered: Oct-07 | i think more then 390 |
New member Username: Manemoj123Post Number: 3 Registered: May-08 | wow im only getting 230 that sucks |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2105 Registered: Jan-08 | 530 tv 70 radio |
New member Username: Manemoj123Post Number: 4 Registered: May-08 | is there a way i can just load channel list from someone on CW600 Premium? can someone maybe send me that file or a link where to go. all the help is apreciated. thanks everyone |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2106 Registered: Jan-08 | ESPN Canada less good TNT i dont know |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2107 Registered: Jan-08 | Do a blind or power scan, if you have lost some Tp That recover lost TP |
New member Username: Manemoj123Post Number: 5 Registered: May-08 | Thank you Plymouth for all your help. last question. is there a way i can just load channel list from someone on CW600 Premium? can someone maybe send me that file or a link where to go. all the help is apreciated. thanks everyone |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2109 Registered: Jan-08 | Bobby do you want a list for load in your receiver? |
New member Username: Manemoj123Post Number: 6 Registered: May-08 | if you have CW600Premium? and do i load it as a any bin? thanks |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2111 Registered: Jan-08 | Yes I have one just to do a Blind scan and you supposed to recover all channels Check if you have only Horizontal(left) channel If yes you cannot receive all channels. Bad contact on cable result in low voltage and low voltage give only half channels |
New member Username: Manemoj123Post Number: 7 Registered: May-08 | can you please send it to me. thanks for everything. also do i load it as a regular bin (Download S/W) option? |
Bronze Member Username: Hi09Post Number: 83 Registered: Aug-07 | to add to this is it possible for someone to share a list of channels that you are supposed to get with 91W i just set mine up yesterday and i dont know what i am supposed to be getting - by the way is it even working for anyone mine is just sitting on auto roll today.... |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2112 Registered: Jan-08 | Sorry Bobby, I cant send to you Why dont try blind scan Why you dont answer me if you have only Horizontal or left signal. You are newbie, i dont know you |
New member Username: Manemoj123Post Number: 8 Registered: May-08 | i did try blindscan but than i dont get any channels. only way is if i do a regular auto scan on CW600P than i pick up 230 channels only. |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2113 Registered: Jan-08 | Where are you located city Please |
New member Username: Manemoj123Post Number: 9 Registered: May-08 | Chicago |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2114 Registered: Jan-08 | You are supposed to have + - 500 channels On your remote "Press OK" and check all channels and see if big H or big V is display. If you see only H on each channels the problem is bad contact and voltage lost. Check it please |
Gold Member Username: KirankumarNO Bashing Post Number: 2673 Registered: Oct-07 | Bobby, something is not right you don't need to go through a lot of trouble to get the channels post your set up how many dish what switch if any antenna settings for all sats and i will fix it for you |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2115 Registered: Jan-08 | Note i listened from north of Quebec WLS Chicago when i was child in end of sixties |
New member Username: Manemoj123Post Number: 10 Registered: May-08 | ok il check that in about an hour i am not in front of my box now. thank you for all your help il let you know if i got everything to work. i am going to try to connect the lnb straight to the box instead of a switch which get me 2 lnbs for an extra 82W but since there are only HD channels on 82W its useless for me. Thanks again |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2116 Registered: Jan-08 | African i dont bash your post Please stay away |
Bronze Member Username: Manemoj123Post Number: 12 Registered: May-08 | my aunt and two cousins live in Quebec. been there once but few times in Kitchner where they use to live |
Bronze Member Username: Manemoj123Post Number: 13 Registered: May-08 | Plymouth i use to get Dicknet for couple of years but now since i moved into a apartment they dont allow dishes. what i do is I put the dish on the ground into a bucket but 110 and 119 are too West for me so i cannot catch signal. 82W and 91W on the other hand i do catch but i just cannot get all the channels to work. ill let you know in about an hour what i did. |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2117 Registered: Jan-08 | OK Bobby do you have a cheap satellite tracker? I read your first post and you are only 70 signal, its too low, under 75 you cannot receive all channels. With your location, you can buy a booster signal, thats help too. How is quality? |
Bronze Member Username: Manemoj123Post Number: 14 Registered: May-08 | Quality 68 Strength 86 All channels are on V. none of them are on the H even after Blind Scan |
Bronze Member Username: Manemoj123Post Number: 15 Registered: May-08 | When I list through Transponders I only get signal on the Vertical ones. Horizintal ones are 0 for both signal and strength |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2120 Registered: Jan-08 | Wow OK try to aligned your dish( upper or lower) Before where you take this file? |
Bronze Member Username: Manemoj123Post Number: 16 Registered: May-08 | what do you mean align upper or lower? what file? |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2121 Registered: Jan-08 | "what do you mean align upper or lower? Sorry its not in linear. "what file?" where you take your bin file?} |
Bronze Member Username: Manemoj123Post Number: 17 Registered: May-08 | where i get my bin file from? What does Horizontal and Vertical transponder stand for? is it setting problem? dish alignment problem? |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2126 Registered: Jan-08 | That could be where you take your file. You can have 2 or 3 different files |
Bronze Member Username: Manemoj123Post Number: 18 Registered: May-08 | ok finally got it. my lnb settings were wrong i had normal instead of ocs dp setting. now i get 414 channels. Thank you so much for all your help |
Gold Member Username: KirankumarNO Bashing Post Number: 2676 Registered: Oct-07 | see you want help but do not want to do what we ask for.so waht is the point of you starting a thread African Gold Member Username: Kirankumar NO Bashing Post Number: 2673 Registered: Oct-07 Posted on Friday, May 02, 2008 - 06:41 pm: Edit Post Bobby, something is not right you don't need to go through a lot of trouble to get the channels post your set up how many dish what switch if any antenna settings for all sats and i will fix it for you |
Bronze Member Username: Manemoj123Post Number: 21 Registered: May-08 | Plymouth does Bell have NBA Playoffs? what channel? Thanks P.S. i know nothing is working now exept locals |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2127 Registered: Jan-08 | Bobby i think you play with us I hope i am not right OCS-DP dont give any channels |
Bronze Member Username: Manemoj123Post Number: 22 Registered: May-08 | that is my lnb setting. you dont have to believe but i got all the channels now. 414 now before 230 with lnb type normal |
Bronze Member Username: Manemoj123Post Number: 23 Registered: May-08 | so does bev have nba playoffs? what channel? thanks |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 2128 Registered: Jan-08 | If that do 2 years you have dish Why you do this error, so easy for everybody? I have a big dish with motor and listen just "free to air" , so i dont know if NBA playoffs is on Bev Sorry guy |
