Silver Member Username: Moey_gSydneyAustralia Post Number: 206 Registered: Oct-06 | Hey guys i need some help in designing a box for my DD 9512. I had help here a while ago designing a box for my cvr and that turned out great. Someone here designed a box on a website and gave me the link. If someone can do that for me i will appreciate it. Thanks in advance. |
Silver Member Username: Moey_gSydneyAustralia Post Number: 208 Registered: Oct-06 | Any box builders out there? |
Silver Member Username: Demon_prideCrowder, Oklahoma USA Post Number: 261 Registered: Oct-05 | I did mine, 2ft^3 at 38 hz. |
Silver Member Username: Moey_gSydneyAustralia Post Number: 209 Registered: Oct-06 | Im trying to use this site http://www.subwoofertools.com/forum/ported-box.asp?Ew=22.5&Eh=15&Dia=6&Xmax=18&V d=1&NumW=1&Vb=2.75&Fb=38&Qts=&Vas=&Fs=&CE=0 to calculate the panel sizes etc. I just need to know the xmax and the driver displacement. Any ideas on how i can find these or what i should set them to. |
Platinum Member Username: Rovin1 15 = 149.1DBsTrinidad & T... Post Number: 13653 Registered: Jul-05 | i had to search DD forum to find out its 0.2cuft sub disp ...i dont think they give a xmax so seeing that theyr rec 16sq"\cuft i try various digits to get what is required try 2.5cuft tuned 40hz .... |
Silver Member Username: Moey_gSydneyAustralia Post Number: 215 Registered: Oct-06 | Ive been looking for 2 days for the damn xmax and displacement lol. Thanks Rovin. Il let you know what i come up with. |
Platinum Member Username: Rovin1 15 = 149.1DBsTrinidad & T... Post Number: 13658 Registered: Jul-05 | no problem id rec between 2.5 - 2.75cuft with 16sq" of port\cuft tuned 40hz gives a decent sql ..... |
Silver Member Username: Moey_gSydneyAustralia Post Number: 216 Registered: Oct-06 | http://www.subwoofertools.com/forum/ported-box.asp?Ew=30&Eh=16&Dia=6&Xmax=18&Vd= 0.2&NumW=1&Vb=2.75&Fb=40&Qts=&Vas=&Fs=&CE=0 Ive come up with this while setting the xmax at 18mm (I have no idea what to set it at). What do you think? |
Bronze Member Username: PeakohmPost Number: 36 Registered: Apr-08 | i dunno if .2 is right, for a 9512 i saw .546 on their site http://www.ddaudio.com/dd/caraudio/enclosureInfo/mountingData.asp |
Silver Member Username: Moey_gSydneyAustralia Post Number: 217 Registered: Oct-06 | Thats quite a big difference. Even though my sub is the older 9512e, i dont think it could be that big a difference. *scratches head again* |
Silver Member Username: Moey_gSydneyAustralia Post Number: 218 Registered: Oct-06 | http://www.subwoofertools.com/forum/ported-box.asp?Ew=30&Eh=16&Dia=6&Xmax=18&Vd= 0.546&NumW=1&Vb=2.75&Fb=40&Qts=&Vas=&Fs=&CE=0 Heres how it looks with the displacement set at 0.546 and 18mm xmax (still need to get the right xmax value) |
Silver Member Username: Moey_gSydneyAustralia Post Number: 219 Registered: Oct-06 | I just saw that the 9512b is 0.18 on the site archive pages. *Bangs head against the wall* |
Bronze Member Username: PeakohmPost Number: 39 Registered: Apr-08 | haha well at least you found what it is now right? at least for the displacement :P |
Platinum Member Username: Rovin1 15 = 149.1DBsTrinidad & T... Post Number: 13660 Registered: Jul-05 | it is NOT .5 sub disp thats a huge error they have on there for mths now to get an idea a 18 btl is only 0.26cuft so there is no way a 12" dd can be .5 ... |
Platinum Member Username: Rovin1 15 = 149.1DBsTrinidad & T... Post Number: 13663 Registered: Jul-05 | ''''''''''http://www.subwoofertools.com/forum/ported-box.asp?Ew=30&Eh=16&Dia=6&Xmax=18&Vd= 0.2&NumW=1&Vb=2.75&Fb=40&Qts=&Vas=&Fs=&CE=0 Ive come up with this while setting the xmax at 18mm (I have no idea what to set it at). ''''''''' thats = to a 14.5sq" \cuft - try increasing the xmax a bit again & play around with some numbers ....i may sound crazy but it worked for me .... |
Silver Member Username: Moey_gSydneyAustralia Post Number: 220 Registered: Oct-06 | Thanks for all your help. I managed to get in contact with the DD Rep for Australia :D He sent me a few designs thatll work with the sub along with panel sizes and everything i need. Im going to use a 2.5cube box set at 40Hz. Once again thanks for all your help... |
Platinum Member Username: Rovin1 15 = 149.1DBsTrinidad & T... Post Number: 13666 Registered: Jul-05 | cool man just repay by posting some pix of what u did & the results ..... ![]() |
Bronze Member Username: PeakohmPost Number: 40 Registered: Apr-08 | nice. did you find out what the real xmax and displacement was finally though? |
Silver Member Username: Moey_gSydneyAustralia Post Number: 221 Registered: Oct-06 | Will do Rovin. Actually he didnt tell me the xmax or displacement, he just gave me several designs thatll work with the sub. Il ask him now and see what he says. |
