Hard hitting subs
in which box will two 12 hit harder im thinking of using the bandpass because I know its the loudest but dose it also hit the hardest
John A
a bandpass would definitely make poor drivers sound pretty good, but if you're going to buy high quality 12s, then go with a slot vented box. a bandpass does not hit some bass notes as well as others.
PORT THAT BOX!!!
port it dude!
Bandpasses are fun. Stick a few real crappy subs in one and crank that amp. Lasts for about a week. Bandpass takes out a lot of distortion, making the system sound good while the subs are dying under the workload. Go sealed or ported any day. Frequency respose is way better. If you put real good subs in a properly designed bandpass, I wish you luck trying to keep your eyeballs from going drunk. Hard on ears to. And on old guy across the streets heart problems.
Hydro
WHy not put 2 Pyramid Imperial subs(150bucks) in a bandpass and hook it up to a Boss Amp(150bucks) for some bad azz distortion but it wont matter in that box all u will hear is the Spl.
