Tweeter wiring
Username: F3m4
I am getting 6 sets of 4 ohm tweeters to go in my towers, and I was wondering if there was anyway to wire 6 together to get a 2 ohm load?
If not then 3?
Thanks
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 2221
You could wire 2 sets of 3 speakers in parallel with those 2 sets in series to get 2.6ohm...
Username: F3m4
Ok, so what kind of output am I gonna be getting from my amp if it yields these ratings:
RMS Power @ 2 Ohm: 450W x 4
RMS Power @ 4 Ohm: 225W x 4
Post Number: 2222
My guess would be around 300 at 2.6. Don't take my word for it.
What amp is this?
Username: F3m4
Crunch P1800.4
Could I possibly wire it even lower? or would the amp not be stable?
Post Number: 2224
Thats as low as you can go with the 6 4ohm tweeters. I doubt that amp will even do rated power though.
Username: F3m4
Do you know of a better amp to get then?
The tweeters need 100 watts RMS
