Username: Dubmc23 Rapid City,
SD
Post Number: 243 Registered: Sep-07
Tuesday, April 22, 2008 - 23:04 GMT i have a kicker kx1200.1 plz help me decide...
Username: Loudon Post Number: 2385 Registered: Jun-04
Tuesday, April 22, 2008 - 23:23 GMT cvx will get louder
SD
Post Number: 244 Registered: Sep-07
Tuesday, April 22, 2008 - 23:26 GMT ok thanks
Diamond Member
Username: Bestmankind Los Angeles,
CA
Post Number: 20470 Registered: Oct-05
Tuesday, April 22, 2008 - 23:35 GMT i love the way the se's sound though. it still gets loud so i'd go with the se.
SD
Post Number: 245 Registered: Sep-07
Tuesday, April 22, 2008 - 23:42 GMT i previously had two of the old type r's with the 1200.1 will the se's go louder then the r's??
Diamond Member
CA
Post Number: 20472 Registered: Oct-05
Tuesday, April 22, 2008 - 23:43 GMT it would be too close to call imo. i've owned both subs. the se sounds better than the type Rs though.
SD
Post Number: 246 Registered: Sep-07
Tuesday, April 22, 2008 - 23:51 GMT yea those are did get pretty loud and they were only supposed to handle 300 rms each and i had them goto about 500rms a piece..
Username: Hittin1 LakeCharles LA.,
La
Post Number: 205 Registered: May-07
Wednesday, April 23, 2008 - 01:19 GMT both are good subs...Depending on size, U could use more power on the cvx's
Username: Chaunb3400 All he does is catch t...,
Alabama
U.S.
Post Number: 14169 Registered: Jul-05
Wednesday, April 23, 2008 - 02:00 GMT honestly Cvx>RE Se really depends on your listening habits and if you want something that everybody else has(cvx's) the CVX's get almost as loud as RE SX's..and sound decent in the lower mid and upper range..one of the best subs for the buck...
Username: Surferdude9371 Im BTL Bumpin
Post Number: 837 Registered: Mar-07
Wednesday, April 23, 2008 - 02:07 GMT crx for spl re if your wanting cleaner sound
Username: Hurricanebr1an Western Burbs of Chicago,
IL
Usa
Post Number: 447 Registered: Sep-07
Wednesday, April 23, 2008 - 15:31 GMT cvx
IL
Usa
Post Number: 452 Registered: Sep-07
Wednesday, April 23, 2008 - 17:49 GMT if you're going for a pair of cvx 12s lemme know. I have one used I would part for pretty cheap and I know where you can get another for cheap as well.
Username: Southernrebel Monroe,
Louisiana
2 DD3515s, 2...
Post Number: 6322 Registered: Mar-04
Wednesday, April 23, 2008 - 18:04 GMT I would have to go RE SE. I like their sound MUCH better. CVX's just don't do it for me. Both are nice subs though.
