Top of pagePrevious messageNext messageBottom of page Link to this message
LK Platinum Member Username: Lklives
Post Number: 10329 Registered: Jan-06
Posted on Tuesday, July 03, 2007 - 01:14 pm: Edit Post Presuming your watching echo7 and echo8.10, along with echo 1/2.. with DP lnb's type, and its pointed correctly.. if this is the case, then your antenna settings should be just this..
lnb type = dishpro ocs-dp freq 11250 ..thats for all sats.. echo 7 should be #1 echo 8 should be #2 echo 1/2 should be #3 or #4 depending on how U cabled it save settings on all sats
Use the SAT button on the remote to select Echostar package.. hit "ok" 2x then watch tv ...
If U have duplicate channels.. just do a factory reset from main menu.. set your antenna settings as I suggested above and then you BLIND SCAN
I am having trouble getting the settings right. Using dish 500 to get e7 and e8-10 with a twin lnb using a dish 34 switch two wires in one out to vewsat plat.When I go to sat. settings e7 appears at the top of the screen of e8-10.The other day when I hooked it up I got just E8-10 I either have it wired wrong(to the switch) or the settings wrong thanks
