Sony Cd Player not working
Username: Mat_1992
I just bought a car and it already had a sony cd player in it it was working perfectly fine until the other day i turned the ignition on and nothing lit up on it i checked all the fuses and everyhting, the only thing i can do is insert cd's and eject them, the radio doesn't even work... PLease help me.}
Username: Kpa2727
Old Bridge, NJ USA !
Post Number: 1095
hmm does it have a face plate? if so sounds like the contacts are worn, take the face off and check the contacts and be careful ! if u need to bend them. other then that a wire came loose and u'll need to pull the radio out to fix it.
Username: Mat_1992
Ok i'll see if that will fix it. Thanks
