Bronze Member Username: ChowPost Number: 45 Registered: Jan-08 | i just bought another fortec lifetime,which had b-75 aready insatlled,i converted it into puff,whats weird is that its not scanning any channels even wit blind scan,it's scanning the tp's but its not being recorded in the sat scan. anybody? |
Platinum Member Username: NydasPost Number: 10247 Registered: Jun-06 | Try reseting first - factry reset and then do user setup antenna setup and rescan. Make sure you know and save your antena setup before starting. The ther alternative is to revert to b60 boot and 294T BIN and then reinstall b75 boot/bin and current b75 BIN Everything you need for 2500/Flu to 2700 conversion in one package. Instructions included. Either b75 or PUFF http://public.box.net/2500_full_kit |
