Diamond Member Username: BestmankindLos Angeles, CA USA Post Number: 20423 Registered: Oct-05 | can someone enlarge these 2 pics and put it in adobe file for me? thanks in advanced. |
Gold Member Username: Big_edge_headMilwaukee, Wisconsin MY SUBS GET ... Post Number: 1975 Registered: Mar-07 | theres a way to enlarge them without distorting them? |
Diamond Member Username: BestmankindLos Angeles, CA USA Post Number: 20424 Registered: Oct-05 | thats why i am asking. i was thinking if you open with a photoshop or something and enlarge it then clean it up, it would be okay. |
Silver Member Username: Kyle_lowePost Number: 892 Registered: Apr-06 | i wanted to but my photoshop is being weird and not opening right now |
Diamond Member Username: BestmankindLos Angeles, CA USA Post Number: 20425 Registered: Oct-05 | ok i was able to enlarge it. how does it look? its a lot bigger than this but i couldn't upload the bigger file on here so i reduced it a bit. |
Silver Member Username: Surferdude9371Im BTL Bumpin Post Number: 815 Registered: Mar-07 | looks good ta me is that the sticker your gonna have made? |
Diamond Member Username: BestmankindLos Angeles, CA USA Post Number: 20427 Registered: Oct-05 | yeah. the black would just blend with the tint on my window so it will look sick. |
Diamond Member Username: BestmankindLos Angeles, CA USA Post Number: 20428 Registered: Oct-05 | ok i found a 800 x 800 file of the dls. i think that should be big enough |
Silver Member Username: Surferdude9371Im BTL Bumpin Post Number: 817 Registered: Mar-07 | dam ya i think so |
Gold Member Username: Kpa2727Old Bridge, NJ USA ! Post Number: 1115 Registered: May-07 | chad what size do u want them in? and do u want them in a photo shop file or a illistrator file? |
Diamond Member Username: BestmankindLos Angeles, CA USA Post Number: 20441 Registered: Oct-05 | the audiopulse sticker is going to be around 12 inches wide and the dls sticker is going to be 6 x 6. so whatever size you can make it would be good. photoshop file would be good. |
Gold Member Username: Kpa2727Old Bridge, NJ USA ! Post Number: 1116 Registered: May-07 | http://download.yousendit.com/2DA4FDB40E0EB039 http://download.yousendit.com/A7EE799C391A0770 heres both un touched in photoshop format. |
Gold Member Username: Kpa2727Old Bridge, NJ USA ! Post Number: 1117 Registered: May-07 | hmm well i think the best bet is what i did i left them in a raw format not sized, cause i thought about it and it would only add compression s i left them as pure as possible. |
Diamond Member Username: BestmankindLos Angeles, CA USA Post Number: 20443 Registered: Oct-05 | thanks man. you're the best. |
Gold Member Username: Kpa2727Old Bridge, NJ USA ! Post Number: 1118 Registered: May-07 | np chad. |
