Help with 4 15s
Username: Surferdude9371
Im BTL Bumpin
Post Number: 813
right now im looking at 4 cvr15s i wanna stay under about 500 and am running off a kx2500.1 in a sealed box. does this sound good or can you suggest better 15s for the price to run sealed off that amp? thanks in advance
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 2618
Run 2 15s ported, ull save space and dont have to worry about spending the money for the extra woofers.
Im BTL Bumpin
Post Number: 814
i really wanna do sealed so i dont have to worry about the music that i listen to sounding good.
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5454
then dont get cvrs and tune low.
Im BTL Bumpin
Post Number: 819
do you have any suggestions? the guy at the shop i go to has 4 in i cant remember i think a crx its sounds awsome and does 154 i know i wont hit that in my truck but should still get pretty loud
Username: 04redmach1
Lagrange, GA USA
Post Number: 1807
154 with sealed subs is on a AC meter. I do a 153+ on a AC with 1 15 Alpha on a 1750 in a trunk car. 2 15's ported will be the way to go. What truck do you have? What music do you listen too? What is budget for subs and amp?
Kevin
Username: Rovin
Post Number: 13604
some of these guys dont know how insanely loud a good single 15 can get yet they think they need 4 of em ....
St. Louis, MO / ASU
Post Number: 2619
With 4 15 CVRs and that amp you wont break 150 sealed on a TL mic. My guess would be 147ish at the most. For some subs sealed boxes are the way to go (ss RL-S)... With 4 15s and with the subs being CVRs, sealed would be stupid. There will be very few educated people on any fourm that would tell you its a good idea.
Im BTL Bumpin
Post Number: 821
i have an ext cab ranger i listen to mostly hiphop but every now and again ill listen to some nice norah jones lol so apples and oranges. id like to be able to stay under 600 and be able to use my kx2500.1 if possible. the 154 was on a tl.
Im BTL Bumpin
Post Number: 822
im sure a single good 15 will get loud i have a fully loaded btl18 right now (which is for sale btw ) that really bumps i just wanted to try a new setup ive had subs sealed b4 and love the sound so if you know some subs that are good sealed thatd be sweet.
Username: Resin3
Post Number: 41
I actually have some Old Man Pops 15's. I got 2 of them they sound good in a sealed box. Best subs I've ever had and they take good rms. They are hard to get from what I heard though, and I bought them off some guy. Sooo try google I guess? =/
Post Number: 5458
btl isn't made to sound great ya know? go with a couple of 15s known for some sound quality, but still get loud.
Im BTL Bumpin
Post Number: 824
hmmm well if im gonna do two subs i guess id do 2 18s so 18 or 15s that are sealed. thnx nick ill check those out.
Username: Drant19
DUB-C, TX
Post Number: 797
why sealed??? you can go ported and still maintain sound quality PLUS you gain output!
Username: •cam•
BC Canada
Post Number: 2429
You might wanna look into the Mach 5 IXL line.
Username: Snowball123
West Allis, WI United States
Post Number: 611
port that sh*t
Im BTL Bumpin
Post Number: 825
well what are 2 good 15 or 18s that i could port and still maintain highs and lows with good sound.
