2 12" insignia Subs. Need help!
Username: Dueceswild16
I am trying to decide if I should put them in individual boxes or have a closed box. I would like to have max performane. Can anyone tell me what would be best?
aim= FuzzyWuzzysWantd
email= logan1616@gmail.com
Username: Haydog_08
Arkansas US
Post Number: 35
Why would u want to put them in individual boxes? u going for sound quality? or bass?...if ur goin for bass get a dual 12" subwoofer box...ported...to a good freq with ur sub :-) for quality i would seal the box..but i would not do individual boxes
Username: The_image_dynamic
San Diego, California
Post Number: 3828
That sub calls for 2 cubes ported. Seeing as how you are probably on a budget this prefab would work:
http://www.sonicelectronix.com/item_7516_Sonic+Sub+Box-+2SBV12.html
Could I make a box as good/cheap as this? http://www.overstock.com/Electronics/Dual-12-inch-Subwoofer-Box/2667497/product. html#moreinfo
Post Number: 3835
Companies that make those overstock type boxes buy MDF by the trainload. It would be possible to build a similar box to the one I posted for cheaper if you have the skills, but the one you posted is cheaply built and is not big enough volume-wise for your subs. If you are going to build one, copy the sonic model. As far as pre-fabs go that is a very nice cab, I have friends that bought them and they work great for what they are.
I could most likely build it to size the only thing is the things on the sides. the ports i believe? I don't know how to get those or put em in.
Post Number: 3837
No, the ports are slotted and are on the bottom. What you are seeing are the speaker terminal cups. Skip using those and drill a hole on each just big enough to fit the wire through on the back behind each woofer and caulk any extra space around the wires.
oooo ok, so i could just build my own. because I already have my subs... www.hackashack.com/VIEW.jpg those are mind I could just buy 3 more sides of wood and finish it.
A pic is worth 1000 posts!!
Post Number: 16092
^^^That's plywood not MDF.
Post Number: 3838
Yes, and that is the worst place to use plywood (the baffle).
Scrap that idea and build a box completely from 3/4" or 1" MDF.
soo it has to be MDF? could i use this then? http://www.sonicelectronix.com/item_7573_Sonic+Sub+Box-+2SL12-2.7.html or is it not big enough?
Post Number: 16093
That box is over $100 with shipping. How are your carpentry skills?
Post Number: 3840
Yes. That box would work fine too.
shitty pardon the language. I'm 16 years of age. I could prolly have my dad do it. but what all would i need.
Post Number: 16095
If you're challenged or under-resourced then buy it made. I didn't know your circumstances.
Post Number: 3842
And this is why I recommended a pre-fab in the first place. Let's face it, the subs you have aren't going to whip up a sonic firestorm, so just buy a pre-fab and go with it until you learn more.
Here are the specs to work with:
Sealed box: 1.2 cu. ft.
Ported box: 2.0 cu. ft.
One 4" x 8-3/4" port
Tuning frequency: 40Hz
Post Number: 7
haha, ya my cusin is really good with subs and all that I might just have him build it for me during the summer when i see him, where could I go about finding MDF and how much would it cost to make the same box as shown earlier?
Username: Joebruce
Mach5Audio M...
Post Number: 1958
Contact BJ Fisher at
www.fishercustoms.com
Im sure he can hook you up with a good price on a sealed box. Prolly be cheaper than the one you listed.
Username: Snowball123
West Allis, WI United States
Post Number: 604
insignia ftl.
Post Number: 8
lol I am poor so I got some descent Subs.
Post Number: 605
hahah thats alright.
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5428
"lol I am poor so I got some descent Subs."
not true. and its decent not descent.
Username: Dakangofkrunk16
Boca Raton, Florida
Post Number: 1562
Home Depot has MDF the lowes by me didn't you can even have them cut it to specs for like 2 dollars extra the MDF was like 28 or sumtin for a big sheet one sheet did my hole box and i had left over
Username: Hdubb
Team Revolution
Post Number: 3570
where are you located logan doe?
