My pansat 2500a wont scan channels
Username: Chow
Post Number: 46
ok i know my dish setup and switches are good because i have another receiver and all sats are good.i have this 2500 to puff i just got,its scanning the tp's but it wont make a channel list so i cant get into the parentl control or cas system.signal and quality are 97%,is there something blow inside the receiver you think? thanks
Username: Nydas
Post Number: 10212
There was one 263_PUFF file, I think the original one by UKR that was slightly deffective. Try Saif or Lothario's BIN.
You will have to go through factory setting
user setup
Dish/antennna setup - one sat only
Blind scan
More antenna setup
Blind scan.
Next time save everything using channel master, before installing new BIN, and restore the settings after new BIN.
BINs - Either b75 or PUFF
[link removed]
http://www.sharpc.com
Username: Chow
Post Number: 47
nalin,i was in another forum and someone said that there might be these two small fuses or diodes that might be blown and to buy them at radio shack.but ill try what you said first thanks
