News about SS Rl-S
Username: Charlesbhs
Dallas, Tx USA
Post Number: 531
ok well i sent my rl-s back because it had been making that really bad noise and so they finally got it yesterday and checked it today and this is what they sent back
"Hey Charles,
Your driver definitely had a misaligned coil that was rubbing against the
interior motor structure. This will be covered under warranty and I should
have a new one out to you by the weekend. Please confirm where you would
like it to be sent.
Out of curiousity, what type of power + enclosure are you using?
Take care,
~Mike"
so yea i guess thats what was wrong with it... god i love warranties
Username: Bonhamd
TC, MI USA
Post Number: 569
that is good news for sure - warranties are sweet
Diamond Member
Los Angeles, CA USA
Post Number: 20348
yeah mike is a stand up guy.
Dallas, Tx USA
Post Number: 533
yea he's a really great guy. hey chad i was thinking of getting a box from hexibase for my rl-s. what do you think about that idea? any suggestions?
Diamond Member
Los Angeles, CA USA
Post Number: 20352
can't go wrong with there boxes. you want to try ported?
you should email mike first and ask him whats the best spec box for that sub. he will tell you its best sealed but if it must be ported, then it needs to be low.
Username: Basebalz13
Moneta, Va Usa
Post Number: 451
wats your plans for it now? trying to sell it?
Dallas, Tx USA
Post Number: 534
Yea either get ported box or sell.
Username: •cam•
BC Canada
Post Number: 2412
Anything less would be an injustice to such a nice sub.
Diamond Member
Los Angeles, CA USA
Post Number: 20354
charles i have put that sub in a 2.2 cuft ported to 30hz and it sounded tight and got pretty loud. i know that box spec is a bit small for that sub but it sounded better to me than when it was in a bigger box.
Username: Frkkevin
Post Number: 4931
i knew something was up with that sub.. for the money sell it as bnib and get yourself two 12s.. i was not too impressed with how loud it got.. low end was great tho
Username: Denim
SoundSolutionsAudio.com, MD USA
Post Number: 690
Mike of SoundSplinter is one of the best.
Username: Th3pwn3r
I compensate...
Post Number: 7940
If only SS could produce subs with aligned coils. They'd be one of the bes companies period. I don't like hearing about these misaligned coils.
Username: Th3pwn3r
I compensate...
Post Number: 7941
However, they could have also told you that the subwoofer was clipped and the coil was damaged as a result but it seems that they're honest over there so that's a great thing. The hassle still sucks when you're going through it.
Username: Frkkevin
Post Number: 4932
*Edit feature ftw
Diamond Member
Los Angeles, CA USA
Post Number: 20358
yeah if you guys met mike from soundsplinter, you would know he is not capable of lying.
Dallas, Tx USA
Post Number: 535
"charles i have put that sub in a 2.2 cuft ported to 30hz and it sounded tight and got pretty loud. i know that box spec is a bit small for that sub but it sounded better to me than when it was in a bigger box."
so is that what you suggest i ask him design? sealed is to quite for me, though it sounds like sexz ;) but like im wondering like ima put like $150 into this box, but do you guys thinks its worth it? like im still scepticle about how big a difference there might be..
Diamond Member
Los Angeles, CA USA
Post Number: 20391
well if you ask mike that, he'll tell you its too small. but for me i liked it. i love the sound of tight bass thats why.
