Bronze Member Username: 360guyOttawa, Ont Canada Post Number: 74 Registered: Dec-07 | This idiot will send you to a site that you can't even back out of. Has nothing to do with FTA |
Bronze Member Username: Kart_57South Florida Post Number: 77 Registered: Jan-08 | Site will lock up your computer!! |
Bronze Member Username: Partner500Post Number: 22 Registered: Apr-08 | Lies. USE THE SIDE NAV BAR http://www.earthhourblog.blogspot.com |
Bronze Member Username: CarburantePost Number: 82 Registered: Jan-08 | PHUCK U JOHNNY LIE |
Bronze Member Username: 360guyOttawa, Ont Canada Post Number: 78 Registered: Dec-07 | I've suggested it elsewhere but will repeat it here. If anyone is asked about Earthhour you should inform people of the nature of those who are involved in it. You know, their tendency to lie, misdirect and have no consideration or appreciation on how their behaviour effects others. Kind of ironic given the cause they are putting forth. Get it Johnie! |
Bronze Member Username: AdirondakPost Number: 11 Registered: Mar-08 | Johnie, I am posting this snapshot of the side nav bar.... either you are blind from all the jerking off.... or you are a chunky load of smegma that you mother should have swallowed.... I vote the latter. ![]() |
Silver Member Username: Postergirl1Post Number: 300 Registered: Mar-08 | pos johnny |
Silver Member Username: The_codersPost Number: 921 Registered: Jan-08 | ![]() |
Bronze Member Username: 360guyOttawa, Ont Canada Post Number: 81 Registered: Dec-07 | Great use of the word smegma. I've been waiting for an appropriate time to use that myself but you sir have definitely used it correctly. |
Silver Member Username: GregrafPost Number: 179 Registered: Dec-07 | ![]() |
