Satellite finder
Username: Greatful
Post Number: 89
do you need to unplug the receiver everytime you reconnect the sat finder my dish is on the roof trying to get bev in.
thanks greg
Username: Kirankumar
NO Bashing
Post Number: 2476
yes yes yes,
always turn receiver off when doing any kind of work on co ax cable or switch,failure to do so may result in damage to switch and or receiver
Username: Greatful
Post Number: 90
but do i need to unplug too
NO Bashing
Post Number: 2477
easy way to install dish is go to www.dishpointer.com\enter your address and sat you want and hit go
keep on double clicking on marker and you will get exact direction from your house
also adjust elevation and skew it is there
Username: Greatful
Post Number: 91
thank you
greg
NO Bashing
Post Number: 2478
you don't need to unplug
Username: Tariq_ashraf
Ihave Pansat 2700A. My all Asian channel has gone one by one (Indian and Pakistani). Please help me.
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 1750
Same for all need new bin
Username: Madflea168
Post Number: 414
I think there still some tolerance with dishpointer.com or the satcalculator.freehostia
I tried to angles on 91, both showed elevation @40.9, but I ended with about 44 to get stronger signals.
it is still a better idea to fine tune with tv/fta near by or a cheap sat finder always come in handy.
Username: Plymouth
Post Number: 1764
If your mat is perfertly adjust
