The big 3
Username: Deadrabit
Post Number: 346
i don't know much about it. i know it is the wires to the alt and some other one. or at least that is what i am guessing.
it sounds like a good upgrade, i just ordered my kinetik battery and i am looking at alts.
help me out on this. which wires do i need and were can i get them at for the big 3 upgrade?
Username: Snowball123
West Allis, WI United States
Post Number: 598
use google mane. haha
http://www.the12volt.com/installbay/forum_posts.asp~TID~73496~PN~1
Post Number: 599
you using 1 gauge in your setup? you could use some leftover from the power and ground wire.
Username: Deadrabit
Post Number: 348
ya i am useing 1 guage but ill have to get more if i am going to do that
Username: Deadrabit
Post Number: 349
thanks for that like snow!
Username: Deadrabit
Post Number: 350
i just got done looking at my car. this is going to be really cheap and easy, i feel stupid for not knowing aobut this before
Username: Loc_out
Santa Ana, Ca Resonant Eng...
Post Number: 1964
We were all there once ben. Take your time and make sure you do a good job.
Username: Goodie_goop
Mid town, Texas U.S.
Post Number: 848
disconnect your battery before you run any wires
Username: Deadrabit
Post Number: 351
ya ill take it out. i know that.
i think i acually have everything laying around to do it with out buying anything else
