New member Username: Morgan1028Ellenwood, Georgia United States Post Number: 1 Registered: Apr-08 | I have a AudioBahn 15 and I need to know what kind of/ size amp I need to get to push it. this is the information I have on the sub: Technical Specification Sensitivity: 94 dB RMS Power Range : 2000 Watts Peak Power Handling: 4000 Watts Impedance: Dual 2 Ohm Low Frequency response: 18 Hz High Frequency Response: 5000-25000 Hz Diameter: 15 Inch Features 15" Subwoofer 360 oz. Magnet Weight 2000 RMS Power Handling 18Hz - 500Hz Frequency Response 94dB Efficiency 3" Dual 2 Ohms Voice Coil 1 Ohm or 4 Ohms Operation 8" Mounting Depth 13-3/4" Hole Cutout 15-3/8" Outer Diameter PHAT 2 Multi-layer Foam Surround Stamped and Balanced Aluminum Cone Dual 2 Ohm Voice Coils 1 Ohm or 4 Ohm Operation 6 mm Cast Basket Multi-connect Lug Lock Terminals Priced per speaker 1 Ohm or 4 Ohms Operation 8" Mounting Depth 13-3/4" Hole Cutout 15-3/8" Outer Diameter Please help me. |
Gold Member Username: The_image_dynamicSan Diego, California Post Number: 3777 Registered: Dec-06 | For the AW1508T you will be good with between 1000-1200RMS without having to upgrade your electrical system. Your truck has an 145 amp alternator so you will be fine inside that range. A good choice for the money would be the Audioque 1200D which puts out 1200RMS @ 1 ohm. It costs $249 + ship and can be found here: http://www.audioque.com/aq/AQamps.htm You would wire your sub like this to get a 1 ohm load: |
Bronze Member Username: Dirtrider125Post Number: 24 Registered: Apr-07 | kx1200.1 |
Silver Member Username: Drant19DUB-C, TX Post Number: 759 Registered: Aug-07 | budget for the amp? |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 5287 Registered: Dec-05 | i'd say audioque 2200D. I know that audiobahn will not handle that amount of power.. but that way he really knows he got the juice to push it |
