Need box plans please
Username: Nickr89
Post Number: 12
ok so i desided to make my own box for my subs
so can someone please help me with what im looking for
2 12" cvr's running on a 1000 watt amp and i would like the box to be ported size is not a facter i have alot of room to work with if you need anything else let me know
thanks
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 5777
go with pete b/c no one else knows how to design a box properly :-\<<<sarcasm>>>
give me your max dims:
perfered tuning:
what vehicle:
and how many and what size subs you got:
i can have a design for you by tommorow
Username: Nickr89
Post Number: 13
toyota camry
2 12" kicker cvr's
1000 watt amp
idk what max dims or what you mean by prefered tuning kinda new to this
Username: Explictx
Glen Burnie, Maryland USA
Post Number: 524
by max dims he means the maximum dimensions of your trunk. and by prefered tuning he means what you want your box to be tuned to. most boxes are tuned in the 30 range for daily.
Username: Explictx
Post Number: 525
Measure the Hight, width and depth of your trunk.
Username: Nickr89
Post Number: 14
i still dont understand the hole tunning thing but i want it as loud as possible
well my trunkj size it
lenght-40"
depth-41"
hieght-17"
but i dont want to use the entire thing still want a little bit of room
but my max would be
length-38"
depth-20"
height-16"
but if you think that it will sound better if its a little bit over my max i can fit it in there
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5349
yeah, dave needs to know the vehicle because he knows so much about the acoustics of so many different vehicles.
Username: Dakangofkrunk16
Boca Raton, Florida
Post Number: 1525
i have a camry.. the trunk is big but not that big.. i got a 3.4 cuft box and it fits just a lil room on sides left
Post Number: 5778
"yeah, dave needs to know the vehicle because he knows so much about the acoustics of so many different vehicles."
no i dont..but at least i can guess sub/port placement...
reece go eat d!ck....
do you want it to be loud and low?
do you want it to be loud as hell
or do you want some SQ
Username: Big_edge_head
Milwaukee, Wisconsin MY SUBS GET ...
Post Number: 1921
Don't hate on Dave. He's a good guy.:-)
Post Number: 5779
thanks steve your not to bad yourself :-)
Username: Redliner
Wilmington, Ma
Post Number: 4263
dave sux lol jp hows it goin kid
Username: Nickr89
Post Number: 15
well i dont know wat SQ is but i want more of a dang and bump rather than loudness if you know what i mean like i want to feal a bang when it hits not jsut like loud sounds i dont know how to explain it
