Sv4000 doesn,t list sat 118.7
Username: Lomna
Post Number: 193
Username: Lomna
Post Number: 194
please help me.
Username: Kambam
Anik F3 (118.8) is not listed on 262 bin file that I loaded for pansat b75.
Is there way to add that?
Username: Nydas
Post Number: 10176
devin: Use 119W twice over.
First with LNB freq of 10750 or less and TP 11715, then LNB freq of 11250 and TP 12224. Or you can modified unused slate and copy everything of 119 except change to the above for 118.7 and call it 118.7. to do a blind scan you need to put in only the first frequency.
Note that this applies to LNBCB2008A with LNB type Universal or circular.
Username: Lomna
Post Number: 195
NALIN......I agin thank you very much. You are always there when we need you.I'm greatful.
