Any other spl meters?
Username: Stamant
LA, FL USA
Post Number: 403
Are there any other spl meters other than the termpro? I know all standerd are set off the termpro, however I don't have the money for one. What else is available that will give me a decent idea?
Username: Big_edge_head
Milwaukee, Wisconsin MY SUBS GET ...
Post Number: 1907
You could always pick up a "boomstick" from your local walmart.Upload
lol. Those things suck.
Username: Dakangofkrunk16
Boca Raton, Florida
Post Number: 1511
try and find a splmeter.com SPL meter check Ebay
They are close to the real thing... but out of business
Username: The_image_dynamic
San Diego, California
Post Number: 3738
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&Item=120245138678&Category=79842
Username: Stamant
LA, FL USA
Post Number: 404
How close to the termpro are both those meters?
Username: Stamant
LA, FL USA
Post Number: 405
How good is the radio shack version?http://www.radioshack.com/sm-digital-display-sound-level-meter--pi-2103667.html
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5305
radio shack version blows... the epic 160 is supposed to be pretty accurate. then again it is normally mounted in the dash rather than on the windshield and you cant move it around to see what youre doing in the kick or legally sealed up. looks sweet under your HU though.
Post Number: 3740
The RS one only goes up to 126dB... not too helpful for car audio. The AudioControl meter has accuracy within a few dB's which is fine for most non-critical applications.
Username: Stamant
LA, FL USA
Post Number: 407
thanks guys.
Post Number: 3741
By the way... the RS version does not "blow". It is used by many audio professionals to tune FOH systems for hot spots and to achieve even coverage in all seating areas. It is not clinically accurate but it is consistent. Meaning if it reads a 110 which is actually 107 on a pro meter, it will still read that 107 as 110 every single time, making it extremely useful for comparison purposes. I have an old one in my audio toolbox and it has worked flawlessly for almost ten years.
Boca Raton, Florida
Post Number: 1512
i think im gonna pick up a epic 160
Username: Nd4spd18
Northwest PA
Post Number: 7333
Audiocontrol meters will give you a flase high reading compared to a TL.
Username: Insearchofbass
Post Number: 8917
"By the way... the RS version does not "blow". It is used by many audio professionals to tune FOH systems for hot spots and to achieve even coverage in all seating areas. It is not clinically accurate but it is consistent. Meaning if it reads a 110 which is actually 107 on a pro meter, it will still read that 107 as 110 every single time, making it extremely useful for comparison purposes. I have an old one in my audio toolbox and it has worked flawlessly for almost ten years."
The radio shack hand held also has a correction chart its the analog version and not all the frequencies are covered in the chart but it will give you an idea ...but the other downfall is it only reads whole db numbers not tenths...but im pretty sure the epic 160 only reads whole numbers too
http://forum.audiogon.com/cgi-bin/fr.pl?htech&983682086&openflup&1&4
10Hz +20.5
12.5Hz +16.5
16Hz +11.5
20Hz +7.5
25Hz +5
31.5Hz +3
40Hz +2.5
50Hz +1.5
63Hz +1.5
80Hz +1.5
100Hz +2
125Hz +0.5
160Hz -0.5
200Hz -0.5
250Hz +0.5
315Hz -0.5
400Hz 0
500Hz -0.5
630Hz 0
800Hz 0
1KHz 0
1.25Khz 0
1.6KHz -0.5
2Khz -1.5
2.5Khz -1.5
3.15Khz -1.5
4KHz -2
5KHz -2
6.3KHz -2
8KHz -2
10Khz -1
12.5KHz +0.5
16KHz 0
20KHz +1
