HO alternator
Username: Loc_out
Santa Ana, Ca Resonant Eng...
Post Number: 1944
I been searching for a HO alternator.
Iraggi offers
"Dominator" Series
220 amp / 130 amp idle
240 amp / 120 amp idle
260 amp / 110 amp idle
280 amp / 100 amp idle
300 amp / 90 amp idle
"Amputator" Series
220 amp / 150 amp idle
240 amp / 140 amp idle
260 amp / 130 amp idle
280 amp / 120 amp idle
300 amp / 110 amp idle
DC
which one should i go with? I notice the higher the amps the lower the idle.
Username: Loc_out
Post Number: 1945
I'll be running
2 300/2 or maybe a 4 channel amp.
one mmats 3500.5.
Username: Insearchofbass
Post Number: 8880
id probably go with 260/130 that way you can have max amperage and a good idle but with the jl amps also your going to need more juice
Username: Loc_out
Post Number: 1946
Do you think i am better off getting a 4channel amp? Yeah that's the amp i had in mind.
Diamond Member
Los Angeles, CA USA
Post Number: 20178
get a 4 channel amp.
Username: Th3pwn3r
I compensate...
Post Number: 7878
Chad, you better get yourself an HO alternator again.
Diamond Member
Los Angeles, CA USA
Post Number: 20180
i am running less than 1500wrms and i don't turn it up. infact i barely play any music that hits hard. mainly relaxing music.
Username: Loc_out
Post Number: 1947
Chad is going to need HO alternator. So do you guys think 260/130 is enough? or should i go with 280/120???
Diamond Member
Los Angeles, CA USA
Post Number: 20182
Username: Deadrabit
Post Number: 333
do u have a link to the site that u found those alts at?
Post Number: 8886
well I think the battery will kick in the extra 20 amps your looking at should you use it...that way youll still have the idle reserve...is there a specfic reason your looking for the extra 20 amps
Username: Loc_out
Post Number: 1948
sean i am trying to get the max output with a good idel.
Any idea the differents from "Amputator" Series or "Dominator" Series
Username: Andrew571
Post Number: 1700
I'd def do 220/150 amputator
with some good batts
Username: Nd4spd18
Northwest PA
Post Number: 7316
Don't get an Iraggi.
Post Number: 8893
"sean i am trying to get the max output with a good idel.
Any idea the differents from "Amputator" Series or "Dominator" Series"
other than the stated facts...no I dont know anything else about the alternators
ok heres another way you can look at it and see what you think youll need based on your plans and goals
at idle 14.4 volts
110 amps =1267 watts 20% loss
120 amps =1382 watts 20% loss
130 amps =1497 watts 20% loss
140 amps =1612 watts 20% loss
150 amps =1728 watts 20% loss
at around 1700 rpm id think (not sure)
220 amps =2534 watts 20% loss
240 amps =2764 watts 20% loss
260 amps =2995 watts 20% loss
280 amps =3225 watts 20% loss
300 amps =3456 watts 20% loss
Username: Loc_out
Post Number: 1950
sean that's some really good information. I am going to run a sigle Mmats 3500.5. I e-mail them and they told me it does 2700RMS @ 13.8 and 3000 @ 14.4.
Post Number: 8902
I just broke out my calculator and took off 20%...so those power amounts I listed are with 80% efficiency...I figured if you could see the power amounts it would help you...how efficient is the mmats or how many amps of fuse does it have...also dont forget your amps running your highs in the decision and the cars basic electrical needs
Username: Loc_out
Post Number: 1951
Mmats are really efficent amps. i currently have a 2100.1 on a stock charging system and it moves my XXX really good. Can't fine any info in the fuse
Username: Bernymac
Cambodia
Post Number: 3852
http://www.qualitypowerauto.com/catalog.php?item=9&catid=41&ret=catalog.php%3Fca tegory%3D41
Post Number: 8908
now thats what im talkin about...160 idle 300 max
Username: Bernymac
Cambodia
Post Number: 3854
indeed
Diamond Member
Los Angeles, CA USA
Post Number: 20197
awesome berny. do they have for import cars too?
Username: Loc_out
Post Number: 1954
Thanks berny now that really helps.
Username: Bernymac
Cambodia
Post Number: 3855
I don't know Chad. I want to get my alt there also, the 300/160 looks awesome. Hopefully they have a clamp to measure amperage so I can see real results.
Username: B3n07
Louisville, Ky USA
Post Number: 838
why dont you check out ohio gen i just talked with the today there selling me my alt for 500 and its able to put out 185 at idle and 215 (what they said)
Username: Bernymac
Cambodia
Post Number: 3856
Gus, if you still want my jl amp, its still for sale.
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5295
i wouldn't buy form iraggi. just me. too many people have gotten ripped off by him.
Username: Nd4spd18
Northwest PA
Post Number: 7329
^^^^^^ exactly why I said "Don't get an Iraggi"
