Bronze Member Username: Will4992NC Post Number: 21 Registered: Mar-08 | http://www.sonicelectronix.com/item_6240_Absolute+KIT1450.html Is this a good kit to install my jl 1000/1 with or should i look for something else? |
Gold Member Username: Nd4spd18Northwest PA Post Number: 7350 Registered: Jul-06 | Don't buy an off brand wiring kit, most times they lie about the wire size, it will have a thick casing and not enough copper. You can't go wrong with kicker wiring kits and you can get them for reasonable prices on ebay. |
