New member Username: Bodie1Post Number: 4 Registered: Feb-08 | I think I messed up loading this fwank7 bin--the receiver is puffing then re-boots then puffing & keeps doing that. thanks! kay |
Silver Member Username: MetallicaPost Number: 600 Registered: Jan-08 | Kay try a hard reboot..try to turn on and off from the back of your box. |
Silver Member Username: Snw7619Bahamas Post Number: 206 Registered: Oct-06 | is there a 162 program for B-75 pansat 2500>>2700 |
Silver Member Username: MetallicaPost Number: 601 Registered: Jan-08 | Island Tv no there none of any 162 bin for B-75 pansat 2500>>2700 FLU out there...only PUFF bin. |
Silver Member Username: MetallicaPost Number: 602 Registered: Jan-08 | Island Tv...i just found 1 for 2700 FLU bin.. not PUFF..go to that link look down at the bottom of the page you will see All_262_b75.z that the bin you need. http://public.box.net/2500_full_kit#page:3 |
Silver Member Username: LauradPost Number: 103 Registered: Aug-07 | I loaded the 262 bins for b75. from the link public box net. No signal/ or quality. I did it the old way scan sat change time/did blind scan and tp, no signal for Echo 9 or 7. Can anyone help on this matter I still have not changed from Pansat converted 2500a to 2700 |
Silver Member Username: MetallicaPost Number: 603 Registered: Jan-08 | Laurad go to your installation and reset all of your SAT back again.. |
Bronze Member Username: RagsPost Number: 15 Registered: Oct-06 | This looks like the most appropriate thread for me - so here goes. Current situation: Had a FLU (2500) - converted to 2700 clone as a BIN 75 - worked fire Converted then back to 2500 - then to Puff and up to 260 - worked fine Upgraded then to 261 - worked fine. Then like everybody - a couple of days back - all went down. Now I see 262.. what do I have to do? My first instinct was to run the BL 1.4 and update the fwwnk bin 262... Then I see advise on going via BOX 420... and choosing screens etc??? any recommendations on what should be done - I dont wanna fry my flu!!! My problem - look forward to your solution recommendations. Thanks Guys! |
Silver Member Username: MetallicaPost Number: 609 Registered: Jan-08 | do it like the way you done it B4.. upgrade it from 260 PUFF and 261 PUFF.. And a couple of days back - all went down...and now it the time to upgrade it to 262 PUFF bin using your BL 1.4 loader..what are you waiting for? here is the link for the 262 PUFF bin..go to the link the first u see it the 262 PUFF bin. http://public.box.net/2500_full_kit#page:1 |
Bronze Member Username: LocnoirPost Number: 70 Registered: Aug-06 | Is 262 PUFF_LMAZ bin out yet, anyone??? |
Bronze Member Username: ChowPost Number: 35 Registered: Jan-08 | hey guys im stating from scratch again from 2500a factory,do i need to convert to b-75 first or can i just go straight puff conversion |
Silver Member Username: MetallicaPost Number: 615 Registered: Jan-08 | No don't convert to b-75..go straight to PUFF.. |
