COMPARE SUBS WITH ME
Username: Beatin_down_yo_block
Okalhoma City, Oklahoma United States
Post Number: 18
WHICH SETUP WOULD BE BETTER..
ONE JL 13.5 W7 ON A 1000/1 AMP OR 2 8" W7 ON THE SAME AMP
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 2...
Post Number: 6289
The 13.5 would give you far more displacement and be louder.
The 8's would save you some space though and still sound good, just not as loud.
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 2565
I would to the 13.5 forsure.
Post Number: 20
my only problem is the car is a 2001 jaguar s type.. now do you think the 13.5 at 1.875 cu ft would fit back there.. because a freind of mine has the same car except his is a 4.0.. but same trunk space, anyway he has 3 8" Digital Designs and it sounds good...
St. Louis, MO / ASU
Post Number: 2567
Ben, if your looking to save space and want a sub that will sound amazing and still get very loud sealed look into the Hertz Mille 380. You can only buy them from Hertz dealers and they go for ~$800-900 which is pretty expensive for a single 15" sub. However you can run them in a 1.5cuft sealed box and they sound absolutely amazing.
Heres a review from car audio mag.
http://www.caraudiomag.com/features/caep_0712_hertz_mille_ml3000/index.html
Username: Tejcurrent
Post Number: 1272
I THINK IT WOULD DEPEND ON THE SETUP. I THINK JL IS ON THE HIGH END OF THE SUB/PRICE RATIO, BUT OF THE TWO I'D TAKE THE 13W7.
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5278
hahaha... follow jakes word, go with the mille.
