Silver Member Username: ShorterthanrichPost Number: 104 Registered: Apr-06 | Just bought two Elemental Design 13Ov.2 subs, and eventually I'm going to need to power them fully. Any recommendations on what amp wouldn't short change these on SQ and power? (also obviously not burn all my money) |
Silver Member Username: Drant19DUB-C, TX Post Number: 740 Registered: Aug-07 | how much do you have to spend.. and just throwin this out there, your going to need a HO alt to run 2000wrms. |
Silver Member Username: ShorterthanrichPost Number: 105 Registered: Apr-06 | Don't worry too much about the budget for it, but I got quoted on a nice amp for $500. I'd prefer less than that, but I think thats a reasonable price to pay for a good amp of this power. And yes, I'm aware of the HO alt situation. I'm hoping t find a 250 amp alot at a god price. Any links to sites that sell HO alts for imports? Amp question still stands. thanks! |
Silver Member Username: Drant19DUB-C, TX Post Number: 742 Registered: Aug-07 | so you need 2000wrms at 1ohm or 2? |
Silver Member Username: ShorterthanrichPost Number: 106 Registered: Apr-06 | the subs are 1000 watts RMS each with DVC4 ohm coils. I'll be wiring to 1 ohm. Sorry that I left out so much information. |
Gold Member Username: Nd4spd18Northwest PA Post Number: 7324 Registered: Jul-06 | www.motorcityreman.com For your alternator. |
Silver Member Username: Pbplayer05Carroll, Iowa Post Number: 600 Registered: May-07 | md3d or even the audioque 2200d but i think that would be pushing those pretty hard |
Silver Member Username: MmaudioconceptsPost Number: 461 Registered: Jan-07 | soundstream pca 2000d autotek mean machine 2000D |
Gold Member Username: HdubbTeam Revolution Post Number: 3552 Registered: Nov-04 | rf t20001bd would be my choice |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 5274 Registered: Dec-05 | audioque X2 i'd say is the best for the money |
Silver Member Username: Pbplayer05Carroll, Iowa Post Number: 601 Registered: May-07 | idk if i would give those subs that much |
Silver Member Username: ShorterthanrichPost Number: 107 Registered: Apr-06 | Justin, why do you say that? I'll be putting them in a properly sized box, tuning the amp correctly, etc. Its unlikely I'll ever be running them at full power with test tones :P If you have good reason - let me know Also, I don't know much about the md3d. Pricing? Those Adioques also look pretty good. How's there pricing? or where do I look to get the amp at a reasonable price? I'm currently considering the Cadence DCA-2500D. Overpowering for sure, but this will let me keep the gains in a comfortable range. And I can get a good deal on it. Open to the current suggestions for sure though! thanks a lot |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 5283 Registered: Dec-05 | check www.audioque.com I'd say a real bang for the buck 389$ for 2200w with quality, props to audioque |
Silver Member Username: ShorterthanrichPost Number: 108 Registered: Apr-06 | Can't lie...all that AQ stuff looks great. I read every word on their website. I'm pretty impressed with their design philosophy, especially on their subs. I missed the price listings the first time I was on the site, so thanks for the help. Any opinions on the amps other than generallu good. I'm just curious of how people feel about them. That price is absolutely fantastic... |
Gold Member Username: Th3pwn3rI compensate... Post Number: 7914 Registered: Jul-06 | I'd run that AQ amplifier over the Cadence amp because Cadence isn't what they used to be. |
Silver Member Username: ShorterthanrichPost Number: 109 Registered: Apr-06 | Isn't AQ not what they used to be also? Moving their manufacturing to China, etc? thats just speculation, correct me if I'm wrong. I don't know much about AQ |
