Silver Member Username: BirdwatcherPost Number: 741 Registered: Jul-06 | Ive tried virgin files, Ive tried flash fail fixes and nothing seems to get my box out of boot mode. anyone have suggestions or should i just trash this box and order another. Its not a clone as ive been using genuine fixes for eight months. |
Gold Member Username: KirankumarNO Bashing Post Number: 2425 Registered: Oct-07 | look at this thread, we are looking for a solution but don't have one right now https://www.ecoustics.com/electronics/forum/home-video/471127.html |
Bronze Member Username: Budgie123Post Number: 37 Registered: Sep-06 | the fact itself proves yours is a clone, davidvandiesel. All you have to do is open up the box, remove the tsop grounding wire (which prevents the box from been killed by the clone killing bin), then load the new bin, after that you can reconnect the wire so the box won't be killed in the future. good luck. |
Silver Member Username: BirdwatcherPost Number: 744 Registered: Jul-06 | thanks Mark, this procedure works which proves i have a clone with brown boards. But it works so thanks for your time. |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 2660 Registered: Oct-06 | Where did yo get your virgin from? Cuz maybe there is a recall |
Gold Member Username: PlymouthQuebec city, Quebec Canada Post Number: 1683 Registered: Jan-08 | davidvandiesel unplug Dish cable In your package box with receiver is furnish a cable RS-232 you must download factory bin with the cable from your computer . Go to: <[link removed]> download this 2 files: PVR/Ultra Loader v1.1 - Firmware Updater ( Serial)you install this one on computer VS2000 ULTRA Factory Bin File - V132 for download with the loader in your receiver close rear switch on receiver open program take file v131 clic to download in receiver and a second after switch on the transfert take 5-10 mins you must see 0000 download the last bin with USB Good luck Note i dont see which model, this is for Ultra |
