Silver Member Username: DureMississauga, Ontario Canada Post Number: 190 Registered: Jun-06 | With 261 puff bin on my puff converted FLU very often I am getting blurred picture going darker and darker and finaly end up with 'Searching for signals' and after a while I get the picture and this process is repeated. This happens mainly in the evening.I replaced the disecq switch, antena cable, AVR cable. No improvement. Is it due to something wrong with the Bin file?. Anybody having the same problem? Pl. help. Thanks |
Gold Member Username: NydasPost Number: 9974 Registered: Jun-06 | Use the latest (standby fix) version, which is just a day old. Use EPG to move up an down the channels and select the appropriate one instead of going directly up and down. |
Silver Member Username: DureMississauga, Ontario Canada Post Number: 191 Registered: Jun-06 | Thanks Nalin for your prompt reply. Now I put the 261standby Bin and using EPG to change channels. So far it is OK. Again Thanks Nalin. |
Bronze Member Username: TejazPost Number: 52 Registered: Apr-08 | fwank7_Jvvh-Team-PUFF_261 (sw21 switch_TEST) -------------------------------------------------------------------------------- This bin is for people who use SW21 switches. I have tested it myself but my setup is a dish 500 to SW21 switch. 119 going to SW21 Dish1 and 110 going into SW21 Dish2. Same with Antenna setup settings. So if you are not using a SW21 switch NO NEED to load this bin. Do a Factory Setting in main menu then when reciever reboots to ON. Put in your antenna setup setting for Echo7 then Blindscan Echo7. After complete go back into Antenna setup put in setting for Echo8,10. If you don't see the Quality bar come in when you put in your Legacy SW setting for SW21 don't worry about it. Exit and save then Blindscan Echo8,10. Again I have tested this with a Dish 500 to SW21 switch so if your setup is different then mine I am not sure if it will work or not but all feedback is much appreciated. It does also work with Diseqc switch as well still. fwank7_Jvvh-Team-PUFF. _______________________________________ DOWNLOAD [link removed] |
Silver Member Username: DureMississauga, Ontario Canada Post Number: 192 Registered: Jun-06 | Thanks krokus |
Bronze Member Username: RogybePost Number: 37 Registered: Dec-06 | I coverted my 2500 to 2700 receiver and PUFF bin 261 ORIGINAL REMOTE from Pansat 2500 dont work, do yo uhave any idea whay and what to do. Thank you. |
Bronze Member Username: Freedom_ritesMontreal, Qc Canada Post Number: 27 Registered: Jan-08 | roger you should some more details. waht doesnot working? loading the new bin? or the loaded bin not working? |
Bronze Member Username: Freedom_ritesMontreal, Qc Canada Post Number: 28 Registered: Jan-08 | roger you should be giving some more details. waht doesnot working? loading the new bin? or the loaded bin not working? |
Bronze Member Username: SherSt anne de bellevue, Quebec Canada Post Number: 16 Registered: Apr-07 | Hi I am facing a problem. On loading the fwank7_Jvvh-Team-PUFF_261 on a converted and tested PUFF, I started seeing PUFF running to F and then again repeating this performance never reaching 'ON' I tried loading different older PUFF bins but all gave error (er 02 or something similar) with all kinds of loaders including BL updater 1.4. I even tried loading b60 boot with same result. what do you think my options are?..........JTAG I do not understand as what actually happened. Guidance and help will be appreciated |
Platinum Member Username: NydasPost Number: 10063 Registered: Jun-06 | You would not need a jtag. Try the quick method of UKR. Got to: http://public.box.net/2500_full_kit In the PUFF directory you will see a quick something subdirectory. Download and read the documents and implement as stated. |
