Cw600s
Username: Jon11
LK or nalin need help: I am a newbie, just got cw600s and loaded the k-round with 1.05 loader instead of 1.04 loader, now I cannot go back to 1.04. How can I fix this problem.
thanks
Username: Kirankumar
NO Bashing
Post Number: 2410
do factory reset then load factory file,and then use loader 1.05
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 1581
Do like African say
If not work switch off on rear panel and keep front power on while and switch on rear panel and you will see Boot now load it.
Username: Jon11
I did all that and when go to scan the sat, the sat gets erased, i did several factory defaults.
Username: Brucester
Post Number: 1419
put factory bin in then put back the new bin this will help
Username: Jon11
Bruce1:
I did that, the problem now is when I scan sat the sat disappears - in blindscan or auto.
Username: Brucester
Post Number: 1420
doyou have a switch if so run the cable from the lmb to your box and see if you sat can be scand that way if it work get a new switch
Username: Sutkra
Or Usa
Anyone,
What are advantages Cw600s comparing to other inexpensive receivers
Thanks
Username: Lklives
Post Number: 15312
none..its just a decent simple to use inexpensive basic receiver with good software support..
personally I would spend a few more bucks, and buy a USB ready receiver like the CW 700s ...nows thats a huge difference/improvement IMO..
