I did blindscan to get the new avail. channels. However, I later lost my internationals, and ppv and now it shows either autoroll or no signal. Any help is appreciated or how to update to get all channels back. Thanks.
1) try to do a hard boot(swtich off 10 secs rear panel) 2)Check your sat setup( change by itself) 3)do a factory default do a hard boot and load bin from dsstesterDOTcom, setup and rescan all sats.
I am in the Southwest. So 119, 148, and 110 I think are the sats. I did factory default and now I have no channels. I need to know how to start from scratch.
Who setup first time for you, maybe he can help you. You dont know which LNB is on which com on your switch and what kind of LNB you have? Which dish you have?
