Neosat iPro 2000 Plus
Username: Rafiq128
Post Number: 86
Any body has neosat ipro 2000 plus. how is the receiver, any information. thanks.
Username: Rafiq128
Post Number: 87
any body ???
Username: Lklives
Post Number: 15314
its a very good receiver...as adressed here already in 50 threads...
SEARCH is a wunderful tool...U will find much info with it..
Username: Rafiq128
Post Number: 88
LK thanks for reply. i was going to buy another receiver, i have already nfusion working great, some body mention that about neosat is also very good, so i wanted to see if some body have this receiver and how is working, so that i can buy neosat instead nfusion . if some body have any problem with this or not. thanks any how for your reply.
Username: Lklives
Post Number: 15316
Since U already have a Nfusion...why buy a Neosat 2000...the Nfusion is a great receiver too..
Advantages of each..
Nfusion...better IKS, and more channels
Neosat...better PVR, and also more non IKS stand alone fixes other than IKS
BTW...the Captain 7000, 7100, and 8000HD have now began using IKS with a very simple adapter , the Dongo....and they also have non IKS cardless files too...get more info at [link removed]
Username: Rafiq128
Post Number: 89
Thanks LK : I want to buy one more receiver, i have 3 cs 5k , this time i don't want to have same receivers, trying diffrent receiver with iks. thanks for your input. i really appriciate your input. thanks. i want pvr receiver, thats why i was asking , if any body have the first hand experience to share. thanks LK again
Username: Quetoidalat
Post Number: 9
Bin Support too slow
You should buy Pansat , viewsat or soviewsat
Username: Rafiq128
Post Number: 90
ok thanks
Username: Lklives
Post Number: 15318
Neosat 2000 has very fast software support for its stand alone, non IKS use..and with IKS, U don't even need "new bins" to update....
I don't know any unhappy Neosat 2000 owners..same with the Nfusion.
If your main interest is just PVR, then I suggest..
Conaxsat Duo or Trio
Viewsat Pro
Username: Rafiq128
Post Number: 91
Thanks LK.
Username: Krishn
Post Number: 109
Bhatti
Only Conaxsat Trio supports DIVX for PVR which is the major pros, however the cons is the very high price.
So it depends on how much you record on a permanent basis.
Username: Rafiq128
Post Number: 92
Thanks Subash for your information.
Username: Krishn
Post Number: 110
Bhatti - you are welcome
I must add that among Conaxsat models, Trio is the only one that supports DivX.
I am not sure if there are any other FTA receivers that support it.
May be a there is way to have DivX capability into a linux based FTA receiver, worth exploring if DivX is of importance to you.
Username: Rafiq128
Post Number: 93
Thank you again Subash: I will try explor all the options. thanks once again.
Username: Krishn
Post Number: 112
Bhatti you are welcome. When you are finished, please post your findings since it will help someone looking for a receiver.
BTW I helped another friend in his decision to buy a PVR receiver who did not want to spend much, it was Captiveworks 700s.
Username: Krishn
Post Number: 113
oops cant edit post it was Captiveworks 800s.
