pics of the box so far, it's sitting on it's back if it looks weird...
Here's my question, front panel seems a little thin for me to be drilling mounting screws into it... I'm going to double baffle, should I worry about it?
there will be 1 front panel over that for the double baffle, not recessed design. So, could I make that a little smaller diameter of a cut since the sub will be mounted 3/4" infront of that on the front baffle? Know what I'm sayin?
that front inside panel is 14.5" tall, the one going over it will be 16" tall. Fi's site says "Sub OD: 15.625' Cut ID: 14.125'" So I think I'll just barely make it... Black - bottom and sides and such Red - inside baffle - Will rest on the bottom Green - outside baffle - will cover the entire front
I guess I'm slow I don't really understand the exact question? If the baffle with about 1/4 inch on either side is just to flush mount it then don't worry about it- it should be fine as long as your cuts are good. I always screw/nail/glue the baffles together throughout.
