Fireguy951 Unregistered guest | There is a lot on the blackbirds, if you have one , are you happy, and do you think that it will be here for a while or should I just wait for direect fix? |
Santos L Halper Unregistered guest | Blackbird is awesome. I have over 1200 channels. No card to program either. GET IT NOW!!!! |
Unregistered guest | What are the chances of the system going down though? |
cali777 Unregistered guest | less than DTV |
Unregistered guest | I gathered that much but being more specific it is possible for this system to go down, correct? I was told that there is no way this system will ever go down. |
Cali777 Unregistered guest | Anything is possible but its definetely more secure than DTV.Do you want to buy an hu card...only $100 |
Unregistered guest | cali777 why do you try to f*ck ppl your new name should be snake sh!t the lowest form of sh!t there is......the blackbird is a wise investmentyou caqn read about it here kbock00@dssmarines.com |
