Kicker 15 L7 vs FI 15 Q
Username: Msand951
Riverside, Ca Usa
Post Number: 57
which would be louder and better. between the two.
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5070
L7 louder. Q better build quality & sound quality.
Username: Hurricanebr1an
Western Burbs of Chicago, IL Usa
Post Number: 397
Those are two entirely different subwoofers.
Username: Kyle_lowe
Post Number: 867
im going to guess that any two different model subwoofers are going to be completely different
Username: Drant19
DUB-C, TX
Post Number: 609
^^Kyle, Br1an meant that one is an SPL sub(L7) and the other is a SQ sub(Fi Q)
Username: Vivi2000
Post Number: 28
The L7 will get louder, but it is not as good as quality as the Fi Q. The Q will sound better and wont break as easy(corners in the L7 tend to blow easier than most subs).
Post Number: 5083
^^ is it just me or did i literally say just that 2 hours before him?
Username: Tejcurrent
Post Number: 1244
Nah, I like Kicker ok, but the Q would be my choice.
Username: Skibum12189
Cleveland
Post Number: 2769
IMO
Kicker Amps = Yes Please
Kicker Subs = No thank you
Fi Subs = Yes Please
Cleveland
Post Number: 2770
Kicker Wiring Kits = Yes Please
Username: Naledge503
Portland, Or
Post Number: 3550
CVX is not too bad, honestly.
Username: Nd4spd18
Northwest PA
Post Number: 7197
Or the CVR. The square ones are the bad ones......
Username: Livin_loud
COD4 Addict ... Level 2 pre...
Post Number: 2342
i dont know how much louder the L7 could be (assuming cone area is about the same) since the Q will handle more power. i've owned both actually haha so i should know but i never had my 2 L7's (15's) fully powered, so i don't for sure. my 18" Q is much louder on the same power that i gave my keekers though
Username: Drant19
DUB-C, TX
Post Number: 613
2 L7 15's werent as loud as 1 18"...on the same power????
something is wrong there then. the 15's shoulda been louder due to the cone area. idk maybe thats just me tho.
Post Number: 2345
i underpowered the kickers though like i said. my amps rated for 1500wrms but i'm definitely not pushing that much since i have a stock alt, and i don't let my voltage drop below 14
Username: Th3pwn3r
Post Number:...
Post Number: 7708
That must have been a crappy install for those Kickers.
Post Number: 2349
^only as good as the help i got on here at the time :-)
Diamond Member
Los Angeles, CA USA
Post Number: 19969
i'd take the Q over the L7.
Username: Th3pwn3r
Post Number:...
Post Number: 7711
With the new tinsels(even though Scott said he tried woven before) in place I'd go with the Fi Q.
Username: Drant19
DUB-C, TX
Post Number: 624
@-Eric-
it doesnt matter how many watts you were running to either set up (L7/Q) if it were on the same amount, 2 15's will sound louder. did you use a prefab box? or did you build it yourself?
Post Number: 2353
"it doesnt matter how many watts you were running to either set up (L7/Q) if it were on the same amount, 2 15's will sound louder"
is it really that hard to believe? 2 very under powered L7 15's vs 1 fully powered Q18. i built the box 8cuft @ 34hz, with everything to spec.
Username: Nd4spd18
Northwest PA
Post Number: 7221
Did you actually meter each system or does the Q just SOUND louder. If you're judging it by the sound then I totally believe it.
The Q would have so much better low end that it could sound louder while on the meter it actually wouldn't be.
Username: Hondaracing
United States
Post Number: 11
nah, idk bout that eric, i know what your saying more cone area, but my buddie had 2 DD 2512 and now he has an AQ hdc3 15 and the fifteen is actually louder, running off same amp he had on the dd's.
United States
Post Number: 13
i meant to say that to abarca
Post Number: 2358
i haven't metered either of my systems unfortunately... so yes M.S., by ear.
Username: •cam•
BC Canada
Post Number: 2397
OMG!!!!!!!!!!!
The enclosure makes a difference????
THIS IS BREAKING NEWS!!!!!
Post Number: 5180
hahaha
Username: Drant19
DUB-C, TX
Post Number: 681
lmao your L7's must have been in like a sealed prefab box. because they SHOULD be louder but whatever, i aint gonna fight with you...
Post Number: 2359
dude... i'm not going to fight either but i BUILT the box lol don't know if you picked that up or not. i do have pictures of it somewhere... i do know what i'm doing for the most part, so please stop referring to me in noob manner when i've been reading this site for over 2 years.
it was probably the box. i ran the design past people on here and was told it was alright. the port was firing into the car, but there was NO other way to do it due to size constrictions. it was built solid, air tight, was large enough, and had correct port size. if you still honestly can't believe me, oh well, i know what i f*cking heard :-)
/me posting on this thread
Username: Nd4spd18
Northwest PA
Post Number: 7245
Like I said I believe it. Probably the low end effect.
Username: Drant19
DUB-C, TX
Post Number: 709
"/me posting on this thread"
finally...
Username: Max_killer
Cherniwzi, Ukraine Ukraine
MTX 9515-best
Username: Nd4spd18
Northwest PA
Post Number: 7256
^^^^^ LMAO
You'd be best advised to stop posting before you make yourself look like a complete idiot. If that hasn't happened already.
