Bronze Member Username: Thump510Oakland, Ca U.s Post Number: 77 Registered: Dec-06 | should I get a new sub or subs? or just a custom box built and see if it would sound better?because they are in a kicker box and they reall dont sound good so wat should I do thanks for anyone with positive input greatly appreciated! |
Platinum Member Username: Nyyfan1315 MAG USA Post Number: 9177 Registered: Jul-06 | "https://www.ecoustics.com/electronics/forum/car-audio/470382.html" Stick to one thread next time. But anyway, personally, I would build a new box for it. Still don't like it, sell the subs, buy one solid sub your choice of size. |
Platinum Member Username: MgbcsLincoln, Nebraska Post Number: 2359 Registered: Dec-06 | You have a 1000-1200 watt amp on those subs? Aren't Kicker Comps like 200 watt subs? |
Bronze Member Username: Thump510Oakland, Ca U.s Post Number: 80 Registered: Dec-06 | i think theyre 450watts a piece. I think thats wat im going to do GET ANOTHER box but im thinking about getting one of those hdc3 15s will that or two type rs be louder? |
