Need help for my viewsat ultra
Username: Robbie12
Post Number: 30
Hello, after my pansat 3500 was dead with the bin 375 i bought the viewsat ultra. All what i am getting is 102 channels on Echo1.2 and 135 channels on Echo8.1 (all p0rn are working, all ppv are missing). can anybody help please!
Username: Madflea168
Post Number: 406
I think you need to capture echo 7 (119) and echo 8/10 (110) to have better chances.
good luck.
Diamond Member
Username: Lklives
Post Number: 15144
I believe U may need to readjust the dish, and make sure U have RG 6 good cable and connections..
and yes u will get more channels on the 110 and 119 than the 148
Username: Nydas
Post Number: 9855
If you dish alighnment has not changed, the problem is likely in the settings and in the scan. Do a Advanced scan.
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 1506
Do a factory default, load last bin and rescan all sat
If not work try a bin from another Website
Username: Kirankumar
NO Bashing
Post Number: 2348
Robert,
post your antenna settings here
also i hope you did not do blind scan,because you don't do blind scan on vs ultra,you do auto search
Username: Plymouth
Post Number: 1507
African blind scan is OK on last bin
