I have tried to get in the new pentxxx channel.using viewsat plat echo7 119 it is on tp12267 20000 H v4367 a4368 p4367. tried auto scan and added tp and scanned buy still no channel.Could someone help? thanks
tooter can you not c/p the info so we dont have to regester at sites or click on links just c/p the info and put what site it come from under it so others can learn from it
Chip, you might have to add that tp. I had tp 12268 but not 12267. So I added it. I still cant get the channel because I only get 66 % strength and about 12% quality. I think I'm gonna have to go up on my roof and re aim my dish.
new files have new sat info, try factory default and then blid scan dont save the channels cause it will come up to like a thousand once you did fd, and bs with no changes saved, do your normal auto scan you should get everything back
Guys, we got this new Adult channel, but this doesn't mean we have now more XXX channels on Dishnetwork. This new channel (Penthouse TV) was added on Dishnetwork 3 or 4 days ago, but it's basically replacing TEN, which was also a XXX channel. We still have the same amount of XXX channels on Dishnetwork.
