Setup of speakers and sub
Username: Pjc3
Hi,
I'm not sure if this is the correct forum to post this in, apologies if it is not.
I have 2 200w speakers 8ohm impedance run at the moment off a 500w 4ohm amp. I am looking to buy a subwoofer, or 2, that would work with my speakers. Would I need to buy another amp? or would the subs power the speakers? Also How would I wire it all up?
Thanks in advance for any help, just ask if i haven't given enough info.
Username: Jan_b_vigne
Dallas, TX
Post Number: 12429
I bet you want the car audio section of the forum.
Username: Pjc3
No, these are in my bedroom, they are technically dj speakers, but i use them at home, much to the annoyance of my parents :P they are soundlab P115CCP if that helps anybody.
My amp is a stageline 500w STA-160.
Dallas, TX
Post Number: 12430
Actually, numbers don't help. If you show us pictures of the front and back panels of the units, we can make suggestions without having to hunt down the information ourself. Asking how to hook everything up is a bit of a large project when we don't know what you're trying to hook up and you can find this information yourself by doing a few searches on the web.
Username: Nuck
Post Number: 10026
Feed us info, Peter, glad to have a look!
