CS4K5K6K-Norw support is badly wanted.Almost three days wait is there. May we expect the genrosity of having a bin 1.71. Norw should either support these STB,s like SV is supporting SV1000 or they should make an announcement that no more support for these old STB,s
The pansat 2500-2700 conversion was great.Now the 2500 can still be used instead of being tossed aside.Why would cxxxsat make a converson bin from 4k.5k.to the supported 6100.If these boxes can be converted this would make people very happy and save work for the cxxxsat coders at the same time.
They are loosing their name and I hope future sales.Their not even offering a solution the way pansat did when they stopped support for some boxes.I think people should post on every site the sxxt support and warn potential cs buyers.
Is it possible to convert CS 4/5/6/k's intoCS6100. May be now the solution is not there,but it can be made possible by some work.
Secondly how system works in case of cloned one. For cloned ones the bin for the cloned STB straightway works or it has to be converted to cloned one. Please reply. I donot know.
i don't think you can convert a CS 5000 to a CS 6100 the main processors 6100 has a Conexant Virgo and a 5000 has a STi5518 so it make a conversion bin unlikely and very difficult or impossible.
damn it, soo many conversations about those 6000, 7000, 8000...i wish i can be a part of these discussions, too bad i have freak'n CS 5000 !!!!!!!!!!!!!!!
anyone have any inside scoop if they are even going to RELEASE it ?!?!?!
I was looking into the CNX vs CW post. I was almost set on the CW800 as I would like the PVR, now I'm confused. Also where do you get the files for CNX?
yeah, after reading your mesg. i called up my freind who has both cnx and cw800, he said cw support is better than cnx , so im gonna get me a cw800 coz it comes with pvr with thesame price as ths cnx mini.
